simple smoke detector
lihle
Joined Apr 12, 2009
83
guys i need you help. i am trying to make a simple smoke detector using a photo transistor and the LED. i have followed the instructions from the datasheet of how to test the photo transistor.
what i have designed is the Photo transistor in direct line with the LED and then i measure the voltage when there is nothing in between LED and the Photo transistor. it gave me 5 V but when i put something like a paper it still give me 5v.
what i want to do is that when i interrupt/place something between there should be no voltage.
what i would like to bring up to you is that for me it is not easy to get components such as the Photo interrupter so thats why i am trying to develop one.
hope you will help me out.
lihle
bertus
Joined Apr 5, 2008
22,922
The LM324 shows the - input at ground.
The transistor will never reach ground level.
Make a voltage divider of two resistors and put the - input in the middle of it.
The resistors can be equal values between 1 K and 100 K.
lihle
Joined Apr 12, 2009
83
thanks for your recommendation. i have done that and it seem working .i measure the voltage at the input pin 2. but my problem is that i cant get the 5v when i put a paper between the LED and the Photo transistor. i tried to reduce the resistance that connect the connector of the photo transistor to 1k.
i would like to ask if the problem might be because i m using an ordinary led.
lihle
18,104
The detector may have a visible light filter on it, and shouldn't respond to a visible LED. But it could be picking up all sorts of other things, like overhead lighting. Try pointing a TV remote control at it and see if you get a response. You could also monitor the receiver with an audio amplifier, so you can hear what's going on instead of relying on a meter. It should make quite a racket when you zap it with a remote.
marshallf3
Joined Jul 26, 2010
2,358
I have to agree, I think the common smoke detecotrs that used this technology operated with IR LEDs at a greatly reduced output level.
Which brings on the question - what does smoke attenuate better? Visible or IR? And what kind of smoke?
18,104
I believe smoke is mostly particulate, and the individual particles are much larger than the wavelengths of light or IR. So I don't think the choice of IR is related to wavelength per se. All wavelengths are scattered or blocked more-or-less equally.
I speculate the choice of IR has more to do with other factors, such as the availability of higher powers IR diodes, or the signal-to-noise issues. Just a speculation.
lihle
Joined Apr 12, 2009
83
i have tried everything regarding my smoke detector circuit but its not working. what i have done is to salvage the IR led usually use in radio remote. i then substituted the ordinary led but still is not working.
what can i do.
18,104
what can i do.
Take a deep breath, divide and conquer. You need to validate each function step by step, eg. make sure the LED is lit, make sure the receiver is responsive, and so on. Check connections for continuity and lack of shorts. Measure voltages at all nodes to verify they make sense, report them here if you have questions.
retched
Joined Dec 5, 2009
5,207
Do you have an ordinary opto-interrupter? An old mouse (optical or not) will have them. These are IR and ready to go.
The IR led and the transistor are matched, so that will reduce the number of problems you are having.
Changing the LED level will adjust the sensitivity to the smoke.
lihle
Joined Apr 12, 2009
83
Thanks i will try to get the optical mouse. as for the photo interruper i dont have it yet.
lihle
