Hello. I have a nightlight that varies it's brightness depending on the ambient light. I want to make it less bright so I took it apart and traced the circuit and have a few questions.
1. It looks like it just uses two series resistors to drop the AC voltage to the rectifier. I this safe or a good practice, seems to me there should be better isolation.
2. If I am correct, the NPN in the circuit is simply a shunt that lifts the ground of the DC portion to decrease potential and dim the LEDs. This also seems bizarre to me. It seems like connecting the emitter to the ground side of the LED string and swapping the positions of the resistors in the voltage divider for the base of the NPN would be better, then the NPN would directly control current vs a shunt. What am I overlooking?
3. Am I correct in my interpretation of this circuit?
