Thanks. I'll try to rewire the whole thing, the LEDs should all be the same so should the resistors, so by rule of exclusion I probably fluffed up the wiring somewhere.
Wire one or two at a time and test as you go this time
I suspect you actually have the LEDs wired like this:
This circuit would behave exactly as you describe.
Please show us a picture of your wiring.
Bob
Well, you have to admit it would explain the symptoms: First LED burns out, second is bright, then descending in brightness. That behavior cannot be explained when wired the way he claims it is.I hope not.![]()
Daaaaaaaamn, told you I'm a total dummy. You're absolutely correct. Here's a photo, the negative wire of the power socket came off, but now that I see the two schematics compared it makes total sense. Thanks very much for that!But the rest of the wiring is incorrect as well. Here is how it should be:
Do you see the difference?
You should one end of all of the resistors connected together to the battery terminal, and the other end of each resistor connects to one LED.
Bob
No multimeter, no problem. what color are the bands on the resistors and are they all the same? If your still wire the same the colors should be Orange, Orange, Brown. A gold band may follow, which is the tolerance.The LEDs are the same except for two that I've blown when the 9V battery was wired to them without a resistor. I don't have a multimeter to test the resistors but I'll take the whole thing apart and test at least the LEDs with a 3V battery and take it from there. Then I'll try and make a tidier wiring, I basically soldered the legs of the batteries to each other with the resistor wherever it was applicable.
Very cool effect. You might consider placing a reflector shade over the LEDs so they are not seen directly from the front, and more of their output gets directed onto the art.Here it is then, fully functional, up and running. Thanks very much again everyone for your help!
Yeah, without a shade they can light up things in the room with the viewer. Hmmm... isn’t that a risk to your eyes? I suppose the intensity is fairly low.I don't know. I kind of like seeing them. Looks good in the photo anyway.
Thanks guys!Yeah, without a shade they can light up things in the room with the viewer. Hmmm... isn’t that a risk to your eyes? I suppose the intensity is fairly low.
