Simple, free wiring drawing program?
Reloadron
Joined Jan 15, 2015
7,949
There are plenty of them. Just off the cuff LtSpice comes to mind. It will also run simulations. Like the rest there is a learning curve. Eagle is another. Really depends on what exactly you want the software to do.
Ron
MaxHeadRoom
Joined Jul 18, 2013
30,813
By 'Schematic' does this refer to Electronic circuitry, or Ladder style electrical drawings?
Free Kicad is one for electronics and very popular.
Max.
Ford Prefect
Joined Jun 14, 2010
245
I would personally recommend DipTrace. My rating 9/10
After a few hours playing around it becomes easy to use and quite powerful. Possible to create user specific components with Pattern editor and Component editor. The forums are brilliant with plenty of users. Ask a question and you get a reply/many replies within a few hours. With the Freeware version pins are limited to <=300 pins. Have been using this for a couple of years and I don't think I would be converted to any other schematic/PCB design program.
I have tried and used Eagle - too complicated and difficult to use for a beginner. My rating 6/10
I have tried and used Kicad - it's ok, but think DipTrace is better. My rating 7/10
LTSpice - Tricky... with a steep learning curve but good for simulations - I had it on my PC for quite a while then tried to do an update and it failed to run. Tried reinstalling onto my Windows 10 Pro 64bit computer but keeps failing to run....don't know why! :( My rating (when it was working) 7/10
ExpressPCB - Used it for quite a few years and is good and easy to use but occassionally has some bugs, releases and updates are not very frequent, forums are not altogether helpful, sometimes have to wait ages for an answer to a question, I do not think not very many users using ExpressPCB. My rating 7/10
bertus
Joined Apr 5, 2008
23,006
Janis59
Joined Aug 21, 2017
1,894
Re: Ford
I had heard many good previously about Your suggessted DipTrace, thus downloaded it from the link You kindly gave, to play with. But Windows is telling .exe of their is unknown extension and cannot be opened by means of Windows internals. WTF??
djsfantasi
Joined Apr 11, 2010
9,237
Re: Ford
What is the full file name of the download? You may have to set File Explorer to show details to see it. For example, it might be an archive file that needs to be extracted.
Another problem could be that the version you downloaded is NOT the Windows version. Hence the file header could not be recognized. Double check the download site.
A third possibility is that in actuality it is NOT DipTrace, but malware pretending to be DipTrace. Where did you download it from?
Ford Prefect
Joined Jun 14, 2010
245
Re: Ford
Hi Janis59, click this link DipTrace you will then come to this screen...
and select DOWNLOADS, then Download DipTrace...
Then for Windows, select either 32bit or 64bit depending on your operating system...
The current version is 3.3.1.3 Dated March 5, 2019
The filename for the 64 bit version is 'dipfree_en64-3.3.1.3.exe' and is 154Mb in size.
Hope this helps
MaxHeadRoom
Joined Jul 18, 2013
30,813
All the Diptrace examples, libraries appear to be geared for PCB schematic capture and layout, I couldn't see any for electrical drawings and ladder?
The question in #4 hasn't been answered.
Max.
Ford Prefect
Joined Jun 14, 2010
245
True, but the TS asked for a 'simple schematic drawing program'
Is there a simple schematic drawing program out there?
But the TS has not yet replied and perhaps he is asking for a simple schematic drawing program and PCB design program.
Ford Prefect
Joined Jun 14, 2010
245
ExpressSCH and ExpressPCB. Get the legacy version, which supports netlist linking to the PCB. If you don't care about that, the newer version has many more features.
Yes, ExpressSCH and ExpressPCB is good.
I used to use the Classic Version 7.8.0 but the Plus version still has some bugs and is still in development. Last release was November 2018.
I think they stopped development on the Classic version because it had problems running on some Windows operating systems.
VictorF
Joined Sep 29, 2022
5
Absolutely agree. I am using DipTrace for years and am happy with this tool.
