if you wish to negate a current vector, the negation will cause the actual vector to flip 180°
thats like marking everything with contrapositive symbols, all the arrows point right but the neg signs mean the actual flow is in opposite direction.
the physical "off" and "on" for a common collector BJT is opposite of 393 input logic.
when input logic is True ( + > -) we get a physical BJT off, no sink. with the series resistors 10k/100k/10k this should leave gate at about 11v
when input logic is False (+ < -) we get a physical BJT on, sink. this pegs fet gate to gnd.
am i wrong, please verify.
sorry to ian, i had swapped out that drive stage to pfet but you quoted me before i could replace the image.
i do not yet know what opto SSR i will use, some are like 20mA, but with that last schematic i posted i needed to flip the output logic because input logic is Day-on Night-off (but "393 on" is bjt off, and "393 off" is bjt on-sink), hence use of pfet.You are going overboard here. The LM393 can sink 16mA. You're only driving an LED. There is no need for external buffering.
