The Electrician
- Joined Oct 9, 2007
- 2,970
If you look at the scope capture for the common emitter amp that exhibited acoustic feedback, you will see that the oscillation occurs at about 500 Hz, which is the speaker resonance. A power transformer works just fine there, and over the band of frequencies needed for an intercom it would be adequate.
This isn't intended to be high fidelity, after all!
