Hi Millwood,this is to illustrate that designing an amp is a lot more than just getting its dc working points right.
Again, I strongly suggest that you pick up a book by Self or Sloan on the subject matter and after that, you will have a lot more appreciation for the issues engineers have to deal with to produce even a half respectable product.
it also shows why so many textbook examples will never be used in the real world,.
In the simulation shown, there is no negative feedback. Since you have a driving source with zero ohms output impedance, any negative feedback is shorted to ground through the source.so the first thing to do is to introduce some negative feedback. The simplest way to do it is to wire the upper resistor to the transistor's collector.
since Vc is at 1/2 rail (roughly), that means my Vb would be halved as well. so to maintain the idle current of 2.5ma, I need to half the Re resistor from 1k to 470ohm.
here is the new amplifier powering a 4.7k load.
it idles at 2.2ma, with a Vb of 1.7v, and Vc of 12.6v. the output is 9v Vpp while driving a 4.7k load (a gain of 4.5x with the load). clearly it is an improvement over the previous design.
so it is other people's fault that you failed to discuss the circuit that the original poster was asking for help on, in his very first post?Actually the OP has two different schematics, one is similar to this, which is what millwood keeps discussing.
I went from this schematic, which was similar to the other schematic shown, and millwood and I spent the next 3 pages discussing apples and oranges. Frustrating. It didn't do me any good to clearly show what I was talking about, so I have to conclude there is an element of arguing for arguments sake.
you mean your failure of understanding a discussion before jumping in? or your failure of recognizing repeated efforts to tell you that they are NOT discussing what you are discussing?Yes, if you insist on ignoring other peoples posts.
that does make you look completely unprofessional,Makes you look less than professional.
It so happens that I did not buy it. I took it out of a little toy I had. I actually have 2 of them which I got from a toy which costs half the price of one mic. I don't fall for such idiotic prices.You do not have a condenser mic. You have a cheap electret mic that was sold at a very high price. It is 21 years old (made in 1988).
It is not sensitive, needs to be powered and needs to be amplified with a preamp circuit.
