While thinking about a problem from another post, I came up with a relatively simple design for a bench-type, constant-voltage/constant-current power supply circuit that allows zero to maximum adjustment of both voltage and current.
This makes it particularly useful for things like charging various battery types and voltages.
Not sure how unique it is, but circuits with both adjustable voltage and current tend to be more complex, so I thought I'd post it for anyone interested (below).
It uses a buffered Howland current-pump circuit for the CC function (U1-A), and an op amp emitter-follower circuit for the CV function (U1-B).
D1 allows the CV circuit to take control when the current is below the current setpoint.
It has a low drop-out voltage of about 1V.
The voltage and current control are both referenced to ground from the TL431, 2.5V reference.
The ground reference means they both could also be controlled from the DAC output of a micro in place of the pots.
The circuit below is configured for a maximum output of 15V and 2A current from a 16V supply.
The sim below shows the output voltage and current for current settings of 0, 1A, and 2A, with a voltage setting of 7.5V.
Note how it goes from CC mode to CV mode as the output load goes from 1 to 11 ohms.
The op amps do need to be rail-rail types.
For more detail on the design, I posted a description here.
