The picture embedded in my first thread. I'm not looking for performance parts. Just want to learn something out of a basic circuit.Why don't you start by looking for what you actually need ?
Much easier.
BTW, are you actually going to use a TTL part? They require too much power. Rather dated. Look for LS or CMOS.
OK to the performance.The picture embedded in my first thread. I'm not looking for performance parts. Just want to learn something out of a basic circuit.
3 inputs connected in 2 inputs AND gate to generate an output. I'm more concerned on where to connect the third input on the IC itself because i'm a little confused right now![]()
My bad. I should have left for him to do part of the effort to solve the problem.hi msie,
Consider what the Output state of the 7408 2 inp AND will be IF both inputs are high, logic '1'.
Then think how you would connect a 2nd 7408 to the 1st 7408 in order to get a 3 input AND logic function.
Do you follow OK.?
E
It's easy to get carried away. I almost posted the full solution schematic.My bad. I should have left for him to do part of the effort to solve the problem.
Almost only counts in horse shoes and hand grenades.It's easy to get carried away. I almost posted the full solution schematic.
How do you properly troubleshoot a simple circuit that isn’t working? | General Electronics Chat | 16 | |
| F | simple tester | Test & Measurement | 10 | |
| F | simple tester | Analog & Mixed-Signal Design | 2 | |
Any simple sine wave generator? | General Electronics Chat | 87 | |
| S | Simple delay circuit, prevent double inputs | General Electronics Chat | 6 |
