SIM800L
Serap579
Joined Jan 21, 2025
6
I am connecting Sim800l to arduino uno. Using rechargeable battery about 4V. The Sim800l cannot connect to the network. I have connected the Sim800l ground, TX, RX, and VCC pins. Nothing else is connected. Added two Sims in two different countries. Anyone used it before and successfully send an SMS?
Ya’akov
Joined Jan 27, 2019
10,259
Welcome to AAC.
The SIM800L can only connect to 3G or lesser mobile systems. In many countries this is no longer available.
Are you sure that you have a 3G system to connect to?
Serap579
Joined Jan 21, 2025
6
I read that RX need to recieve 3.3V while Aurduino Uno transmit it's TX using 5V so Between Sim800l RX and Arduino TX a resistant should be applied.
Ya’akov
Joined Jan 27, 2019
10,259
Unfortunately, if you connected the 5V TXD from an Arduino to the RXD of the SIM800, you may have damaged the module.
The right way to do it is using a level shifter. But if you’ve already tried to send data at 5V, you may have a deaf module now.
meth
Joined May 21, 2016
304
This is an excellent tutorial which should answer most of your questions, also points out the mentioned problem with sending 5V on the TX line from the Arduino to the module:
https://lastminuteengineers.com/sim800l-gsm-module-arduino-tutorial/
So I would say follow this step by step, and if you still have problems, please first show us your wiring diagram. Even if you are using a battery for the module and other 5V supply for the Arduino, their GND's must be connected in common.
Serap579
Joined Jan 21, 2025
6
Than
Thank you so much. I will.
