Signal Sequencing
Jaweria Alam
Joined Dec 22, 2024
15
I want to design an OLED driver board that follows a specific signal sequence. During power-on, the order should be: VCLK first, then 1.8 V, then 5 V, and finally the reset signal. During power-off, the sequence should be the reverse: disable the reset signal first, then turn off 5 V, then 1.8 V, and finally VCLK.
Reloadron
Joined Jan 15, 2015
7,948
What you are asking is not difficult but you have left a few things out.
I assume VCLK is a clock voltage? Then 1.8 V and 5 V are supply voltages? What if any is the load current? You also don't mention any delays? The word "then" does not spell out a time delay. I want to turn on VCLK and then after a 500 mS delay turn on 1.8 V and then after another 500 mS turn on ... You get the idea. You can do this using a simple uC or discrete components? What exactly would you like or want?
Ron
ronsimpson
Joined Oct 7, 2019
4,812
Last time I did this we used a 8-pin micro. It started out as a power up sequencer, then added a fan/temperature function then I used the internal EEPROM to hide the serial number and added a "hours of use counter". We had a problem of an item sitting in storage for a year then not turning on for the first time. People want a 1-year warranty and don't like to buy a dead unit that we say is 2 years old. If it had only hours of use, they got a replacement.
