Signal Generator using OP AMP can't produce triangle waveform
xso111
Joined Oct 12, 2017
24
i've searched some articles and learned that if you feed a square wave in an integrator you'll be able to produce a triangle wave. also you need to have to match the frequency of the input to the RC of the integrator.
my op-amp multivibrator indeed produces a square wave which has the same frequency as the RC of the integrator and yet i'm still recieving a square wave at the output of the integrator. pls helpcant get triangle 2.png
