signal amplifier
Toxicant
Joined Nov 7, 2021
9
Happy new year everybody!
I made a signal amplifier which amplify from the 0-5V rectangular wave to -5-+5V rectangular wave. The schematic and simulation are attached.
But after I test the board. The output are not what I expect. Below are the input and output wave.
Thanks and any help is greatly appreciated!
sghioto
Joined Dec 31, 2017
8,756
Besides the schematic did you verify the -5 volts in the circuit?
If you look at the first schematic it shows a battery + going to pin 11
sparky 1
Joined Nov 3, 2018
1,218
The LT1639 has specialized characteristics. You can find reviews about it's different applications.
Here is one, a 5V battery charger and display : https://www.eeweb.com/battery-charger-display-using-lt1639/
In the same category LT1490 which is related.
We find applications using single supply 5V however low frequency tiny signals uses 3V THD best @ 2.6V or less.
Some are quite different from garden variety op amps.
Another is a sound level meter for ultra low frequency with high pass filter with gain stage followed by a unity gain, Vcc is 5VDC : https://arduinosoundproject.wordpress.com/step-by-step-guide/
shown page 7 Fig : DATAQ Circuit takes advantage of the lumpy disposition while looking for artifacts
https://www.ijeat.org/wp-content/uploads/papers/v3i1/A2247103113.pdf
