Sick horizontal on oscilloscope...
Externet
Joined Nov 29, 2005
2,678
The post did not take the whole picture, get messages of 'too long' and all pictures need to be cropped.
Brightness, position, focus, mag, time, mode, attenuation... all work.
The +220V 'rail'
Cathode of D1101 constant 100V, zero ripple, referenced to ground chassis.
I assume the zero ripple is because it is clipped.
Something that bothers me is
Across C1101 there is minus 25V !
Then, the +120V rail becomes clipped to +95V/+100V at the +220V rail.
If the ground side regulator TR1102 is holding ground too 'high'; the differential to the +220 rail would collapse the +220V rail, wouldn't it ?
The way that regulation-to-ground works regulates simultaneously the +120V rail and the +220V rail, right ?
TR1102 is good.
Externet
Joined Nov 29, 2005
2,678
Minus 25V with digital volttimeter, referenced to capacitor negative. Some times shows minus 27V to minus 30V, depending on how long it has been powered up.
That is the variance I report as +95V to + 100V presence at the +220 rail referenced to chassis ground.
Which is a +120V rail minus the C1101 voltage.
AlbertHall
Joined Jun 4, 2014
12,653
Reference to common chassis ground, D1101 anode is 150V peak; cathode is +95 V -no ripple.
This means that at the peak of the anode voltage there is 55V forward bias on D1101 - this is impossible.
Unless:
1. D1101 is open circuit or otherwise disconnected somewhere.
2. D1101 is fitted the wrong way round.
ebp
Joined Feb 8, 2018
2,332
Do we know the AC voltages, measured on the right hand side of the connector, between the transformer yellow lead and each of the other transformer leads?
JoeJester
Joined Apr 26, 2005
4,390
You may have misunderstood the instructions.
At P1101 use pin 6 (yellow) as the reference (black meter lead). Then measure and record pin 1 (Brown) pin 3 (Red) and pin 4 (orange) .
Externet
Joined Nov 29, 2005
2,678
OK.
Yellow as reference,
brown is 170VAC
red is 134VAC
orange is 91VAC.
With R859 that supplies the horizontal section disconnected, the +120V rail is still +120V,
and the +220 rail is +117V.
The capacitor C1101 now shows only -3VDC. Was -27V in sick condition, should be +100V that added to the +120V rail should produce the +220V
The screen trace shrunk to half a horizontal division, as expected, almost inexistent sweep.
dendad
Joined Feb 20, 2016
4,641
That does not add up.
If you have 120V on one end of C1101 and 117V on the other, how can measuring across it now give you -3V?
There is something wrong with the circuit or your measurments.
AlbertHall
Joined Jun 4, 2014
12,653
No, that does add up. 120V tail at 120V, 220V rail at 117V so there is 3V reverse bias across C1101 : so -3V
dendad
Joined Feb 20, 2016
4,641
Blame it on me waking up at 2:30AM and then answering at a bit after 8AM. I read it as 217V, even tho' it is 117 and I typed 117V.
Even after 2 coffees!!
I think , recheck D110.
JoeJester
Joined Apr 26, 2005
4,390
I think it is fairly rare for a production unit to match the schematic and BOM in all respects.
I think it's poor performance to eradicate the parts from the BOM and not eradicate them from the schematic. If they were used on different models, they could have put a note in both locations.
Poor management of their documentation.
