Sick horizontal on oscilloscope...
Externet
Joined Nov 29, 2005
2,683
Hi.
Can someone explain the way this power supply works ?
There is +120V instead of +220V as supposed at D1101 cathode. D1101 and C1101 replaced. AC is OK.
All other voltages are fine. Horizontal sweep is narrow, half the screen width.
it's hard to figure out where you took your reference from.
The conection to chassis is really wierd.
Start is generally:
1) inspection
2) power supply magnitude and ripple.
What is R1101? 100K?
You can say that across C1101 the voltage has to be <47 V, but not relative to ground.
Watch any test instruments that share ground with this thing.
The 120 VDC supply are being linear regulated on the "ground side"
You have an unregulated voltage across C1101.
AlbertHall
Joined Jun 4, 2014
12,663
If the +120V is very low (20V?) then first check the +8V and -8V supplies as these are the references for the +120V supply regulator.
If these are OK, is TR1102 getting hot? If it is then the problem is likely to be that the +120V supply is overloaded. If it is cool then the problem is in likely in the regulator circuit.
Externet
Joined Nov 29, 2005
2,683
Thank you.
Reference taken from common chassis ground. D1101 cathode is +95V to ground, supposed to be +220V referenced to ground.
P1105 terminals have solid perfect values, no ripple and supply all the oscilloscope circuits . Only +220V (not labeled on first schematic) is faulty.
R1101 is 100K
Across C1101 there is minus 25V !
TR1102 is barely warm, like 50C. Checked its junctions, OK at 0.6V.
Previous schematic was from user manual, this, same section, from service manual :
Externet
Joined Nov 29, 2005
2,683
Confirmed continuity 0.1 ohms P1101-1 to anode of D1101.
100.1VAC at D1101 anode respect to chassis common ground.
168VAC between brown and yellow secondary.
132VAC between red and yellow secondary.
36VAC between brown and red secondary.
Externet
Joined Nov 29, 2005
2,683
The +220V supplies the horizontal amplifier section (by right, top) :
Left 2 waveforms OK. all 4 others clipped.
AlbertHall
Joined Jun 4, 2014
12,663
D1102 to 1105 healthy junctions at 0.6V; that bridge and section yields +120V properly.
Just in case:
You cannot check those diodes while still in the circuit because of the very low resistance of the transformer. You must at least lift one end of each diode to check them.
Externet
Joined Nov 29, 2005
2,683
Thanks. Diodes junctions were tested with P1101 unplugged from the secondaries. Both bridges healthy and both yield proper voltages.
Externet
Joined Nov 29, 2005
2,683
Applied 12V to removed original C1101 and retained charge to a couple of minutes later, as my capacitance meter goes only to 20μF. Replaced anyway with 400V rated one.
Not removed C1102 shows 170V across and little 7.8V ripple. Removal would mean risking like 20 tiny connectors and front panel nuts to pull the board out, which will not allow to put to work and probe when removed. Waiting as last resource to do it.
Externet
Joined Nov 29, 2005
2,683
Thanks. I will try to extract the horizontal section magnified from the .pdf
Seems I cannot. The file shows a padlock with its icon, and unable to capture the page and paste here. Retrying with unstitched screenshots... I cannot even put this text on top of the 4 images that make the page.
The bottom image did not take... retrying in next post.
Externet
Joined Nov 29, 2005
2,683
Thanks, Mr. Chips for a decent schematic.
Voltage across fusible resistor R859 is 1.5V (not blown)
Did not find +220V on the vertical amplifier. Uses +120V.
