I apologize for my delay in responding to you. I had other things in my life that had to be done.
Vcc as of now is generic power adaptor 20v 5A.Let's start with basics. Where does Vcc come from? What max current can be drawn from Vcc and what is Vcc when that current is drawn? Is the Vcc source grounded or isolated from ground? What polyfuse are you using? What is the cold resistance? What is the resistance at whatever max current you intend to pass through it during normal (i.e. not a fault condition) operation?
Thanks for info. I can find only F1 in schematic CD_SW.pdf. Are F2, F3 different devices in schematic or alternate types/info for F1?
OK; I found F2, F3. You must keep me updated on schematic changes you make. Now we will work from CD_SW_3.pdf.i have redrawn the schematic a bit. so its only F3 and F2 both on the right
