Hi.
In the datasheet of the L78XX regulator from this address:
https://www.st.com/resource/en/datasheet/l78.pdf
There is a design consideration in 6.1 section.
Among other things,it says:
"...In many low current applications, compensation capacitors are not required. However, it is recommended that the regulator input be bypassed with capacitor if the regulator is connected to the power supply filter with long lengths, or if the output load capacitance is large..."
What current value is considered to be low current applications and what value is
considered as large capacitance?
