Should HPF be higher than expected frequency range and LPF lower?
Ian0
Joined Aug 7, 2020
13,267
You mean the 3.3uF just before the diode? I didn't know I needed a discharge path for it. How should it be? Do you want me to turn it into an HPF? Because I tried that with HPF 0.48 Hz and it doesn't get rid of the noise.
Yes, the diode will charge up the capacitor. You don't show a pull up or pull down resistor on the input of the micro. When the capacitor gets charged up, you will have a DC offset on the output, because there is no way to discharge the capacitor.
Exactly, how are you proposing the measure the output of this system?
Audioguru again
Joined Oct 21, 2019
6,826
The circuit has a voltage gain of 200 times. Then an unshielded input cable and wires all over the place on a breadboard will pickup all kinds of interference noises.
