Shorted MOBO while changing LVDS ribbon cable. NO POWER ON LIGHT ...PLEASE HELP or GUIDE!!!
Mobileslservice_TT
Joined Aug 9, 2019
Hi all,
New here so i'm glad this forum exists...really. I trust more on this forums than even my own knowledge, sometimes, i believe we all learn something new everyday.
Well to make it short:
Laptop T.Satellite C655D-SP5024L lost display looking around cable LVDS seemed broken...now...while handling the "new" LVDS cable, i made wsomething rong of course, and i noticed a brief spark in the mobo connector of the LVDS. After that the green light when adaptor/charger was connected didn't turn on anymore.
While testing phisically the only thing i noticed is a little burn in the mobo connector of the LVDS but the pin works. Now i tested the coils in different circuits and i think i have a short in the first circuits after the power fuse...but i would appreciate some guidance. Since i'm actually a network technician not formerly and eletric/electrician formed.
Looking around i saw that first thing would be to track down shortage area with the OHMs while checking power coils....did that and i think i found a circuit whihc has the short...but not sure and even if true not sure how to proceed.
Schematics are available and basic knowledge i have so...just proper steps to assure diag and then see what to do next.
Thx to all really!!
dendad
Joined Feb 20, 2016
4,641
I think the best thing is to bin it.
It sounds like you have sent wrong volts down the wrong path. Anything could have died.
Mobileslservice_TT
Joined Aug 9, 2019
Well it could be fixed anyway right (with patience/time etc)?...still i understand and actually share your thoughts ;). The weird is nothing seems damaged...voltaje surge would have made noticeable damage or not?
Anyway i'm also learing here because i could learn about PCB/mobo diag/troubleshoot techniques. I have time... and actually like this so...any guidance will help and will be appreciated.
Locally i already found a replacement mobo but different version...and also found a replacement display. The drawback is that locally all spares are from second hand markets...believe it or not bringing something from us/asia is unnafordable in terms of benefit/cost/time ratio.
