short string compression
bug13
Joined Feb 13, 2012
2,002
Ok! I guess you have got it. I was just clarifying so we all were on the same page. Hope you weren’t insulted.
Every reply is appreciated, every reply is helpful in a different way. Collectedly with all the replies, it usually lead to a solution one way or the other. This is a great community because of you guys!
WBahn
Joined Mar 31, 2012
33,084
06 ASCII encoded would be two bytes:
0x30
0x36
You can reduce the number of bytes by a factor of 2 by sending straight binary, e.g. 0x06.
He has said several times that he can't. He has NO control over the comm channel protocol, which accepts only the ASCII codes for the 16 hex characters plus two specific control codes (SOF, and EOF). If he sends anything else to the comm module, it will simply ignore it.
WBahn
Joined Mar 31, 2012
33,084
The first byte are sub group of the device, there are other devices on the same channel as well. I forgot that myself when I first try using smaz lib.
So the SUB needs to stay.
I think I will combine 2 - 3 raw bytes by lookup table, take away one or two raw byte that doesn't need to send that often. it should solve my problem.
So for the fields that you want to combine, how many possible allowed combinations are there? You will need ceiling(log_2(N)/4) characters for N combinations. So you really need to take the time to determine how many possible combinations there are.
bug13
Joined Feb 13, 2012
2,002
You seem to have a very constrained comms channel. May I ask why the channel is so restricted?
It's a system designed by an engineer many many years ago. Maybe between 15 - 20 years. It's still been used, and it's reliable. I personally think the design is brilliance (at the time).
  1. It's low cost, all the device interface with it just need 2 transistor and a low cost MCU with pin interrupt
  2. Multiple master, priority is build into the physical level, similar to CAN bus (dominant bit and recessive bit stuff)
  3. Low baud rate is properly limited by the bus distance required at the time.
RobertPink
Joined Sep 25, 2020
7
I wish I could help but if you are collecting unpredictable data I can't see how you get around the problem. No chance of tokenising any of it?
bug13
Joined Feb 13, 2012
2,002
No, can't tokenizing any of it. It's a multiple masters bus, they all send unpredictable data. But I think I have a solution now, there are a couple bytes that are not "real time", so I can take them out. And as other members suggested, I can work out the maximum possible combination I actually need, and pack all the bits together.
I should be able to reduce about 5-6 bytes, I just need to do the actual work to make it happen now :)
RobertPink
Joined Sep 25, 2020
7
That's good news. I hope it goes well.
