Short Circuit or Open circuit
mothermohammad
Joined May 17, 2014
69
I am thankful if you say me what is happened to a Power switch after its fault?
Does it act like a short circuit or open circuit? and why?
Thank you so much.
danadak
Joined Mar 10, 2018
4,057
Mechanical switches, in general, can fail open or short, or when closed poor contact resistance
resulting in significant current degradation.
Regards, Dana.
BR-549
Joined Sep 22, 2013
4,931
A fault is any malfunction. Not a certain or specific malfunction.
You need to test/disassemble the switch to determine the malfunction/fault cause.
-live wire-
Joined Dec 22, 2017
959
At least check continuity and voltage when being operated if you can. Voltage for live circuits, continuity if they are not powered.
