Transistor Q752 not getting base current. I checked with the same GND you told me to use and I put the red probe on the base of that transistor and I got nothing. that base is going straight to the big IC. so it is not getting signal to on the transistor.Does the relay respond to power sw press ?
and when I on the power switch I am hearing click sound. so I feel relay going click and then nothing happens.
that means the relay is the culprit?
