MaxHeadRoom
- Joined Jul 18, 2013
- 30,873
Hi KAN3KI5, I've received ths exact project and have been assigned the same part as you (controlling the speed of the motor) for my design module. Can you please explain how you went about controlling the speed, I feel highly confused.Hi. I've received a task recently as part of a design project. I'm going to be given a 24W 230VAC shaded 2 pole motor in order to be used as a variable speed fan. The fan is supposed to sense temperature and adjust the speed of the motor accordingly. I need to know the best method for achieving this (controlling the speed, not the other part). I have researched and have come up with simply lowering the voltage to the motor but it seems to be destructive to the motor. Any tips?
Hi,That is NOT a good idea. You really need a frequency controller.
Define "best".Please may you explain the best method for controlling the speed as that is my part of the project.
See Fairchild APP's AN-3006 and AN-3003.. Please may you explain the best method for controlling the speed as that is my part of the project.
I'm sorry by "best" I meant the simplest way to do it. The buzz won't be a problem. In the project there also has to be isolation between low voltage circuitry and high voltage circuitry so how would I go about doing that while also using the triac to control the speed? My initial thought was to use an optocoupler but I'm not sure how it will fit in with the triacDefine "best".
A simple way is to use a TRIAC to chop the AC waveform to reduce the average voltage and thus the speed, but that often causes a buzz from the motor.
Would that buzz be a problem?
Did you see the MOC3023 application in AN-3006?My initial thought was to use an optocoupler but I'm not sure how it will fit in with the triac
I will give that a look and get back to you, thank you!Did you see the MOC3023 application in AN-3006?
It depends upon the load.I tried to control a shaded pole motor using the phase chop technique, and didn't like the results.
The may run hot at full load, but you are reducing the average voltage and speed, which significantly reduces the load from the fan, so I don't see how that's problem.The problem is, the 2 pole AC shaded pole motor is about the least efficient motor out there and therefore tends to run very hot.
The reason they are mainly (or only) seen in fan usage, is that the fan also provides cooling, lower the rpm and lower the air flow.The may run hot at full load, but you are reducing the average voltage and speed, which significantly reduces the load from the fan, so I don't see how that's problem.
Yes, but you also significantly lower the load.lower the rpm and lower the air flow.
The motor in question belonged to a sump pump... so the load was kind of high for that sort of motor.It depends upon the load.
I've been able to control a fan, which is a non-linear load, quite well with a TRIAC lamp controller.
