Hello all,
I have to design a circuit according to this question:
Using any design techniques learned, build a circuit that converts a 4 bit binary input into a hexadecimal character (0-F) on the seven-segment displays.
The seven-segment displays also follow inverse logic (ie, a 0 means that the light is on).
For example, to display the number 2, you would set HEX0[2] and HEX0[5] high, and
leave the rest low. To display an 8, you would leave all values low.
I know I can just use a truth table and K-Map for each output but that seems to be exceedingly tedious. Is there a simpler approach to this problem that I am not seeing? If there is, does it have something to do with the inverse logic part of the question? Any nudge in the right direction is greatly appreciated.
Cheers,
Ben
Cheers,
Ben
