Setup not working-Arduino
Man10
Joined Jul 31, 2018
205
I connected a bts7960 board to a mabuchi 555 motor and I connected the bts7960 board to a 8 volt battery. I connected the bts7960 board to an arduino uno. The arduino uno is suppose to pick a random number. There are only 3 possibilities. They are 0, 1 and 2. If it picks a 1, it lowers a rock and then raises a rock. If it picks a 0 or 2, then it's not suppose to do anything. However sometimes it picks a 2 and lowers the rock and will not raise a rock.
This does not happen every single time. Sometimes it picks a 0 and lowers the rock and will not raise the rock. This does not happen every single time. Why is it not working as intended? If it were then if it picks a 0 or 2, then nothing would happen. But it sometimes lowers the rock, when picking a 0 or 2.
Man10
Joined Jul 31, 2018
205
C:
long v;
Void setup() {
pinMode( 6, OUTPUT );
pinMode( 5, OUTPUT );
randomSeed( analogRead(0));
Serial.begin(9600);
v = random(0, 3);
Serial.println( v );
If( v == 1 ) {
analogWrite( 6, 100 );
anologWrite( 5, 0 );
delay(300);
analogWrite( 6, 0 );
delay(4000);
anologWrite( 5, 100 );
delay(300);
delay(4000);
Mod edit: code tags-JohnInTX
Ya’akov
Joined Jan 27, 2019
10,285
setup() runs once, to set up various hardware and constants.
loop() runs after that, and loops until it is terminated.
If you want something to run over and over, put it in loop().
Man10
Joined Jul 31, 2018
205
I don't want it to run over and over. I want it to run only once when I start the program.
Man10
Joined Jul 31, 2018
205
long v;
Void setup() {
Serial.begin(9600);
v = random(0, 3);
If( v == 1 ) {
analogWrite( 5, 0 );
delay(300);
delay(4000);
analogWrite( 5, 100 );
delay(300);
delay(4000);
Man10
Joined Jul 31, 2018
205
This is the code I wrote in the arduino ide. When I tried to copy the code I used onto the forum I made some typos.
trebla
Joined Jun 29, 2019
599
The code should work, unless Serial.println() does not interfere with PWM setup. You can insert a second long delay after print command to be sure. But i suspect loose wires, maybe from pin 6 or supply.
