How to set an ABM to output certain frequency at certain voltage? Also, how to square some specific node? An example will be so helpful!
Analog Behavioral Model (ABM). Got your messageWhat's an ABM?
Yes, I did look for an answer there then felt lost and ended up here. I attached the BV pdf just to make sure whether thats what you mean or something else.Do you mean the BV (arbitrary behavioral voltage source)?
Have you looked at the LTspice Help File for BV?
Hmm now I am a little bit confused! Is the ABV same as ABM or not?No, that's for a standard voltage source.
Here's the ABV file.
If you show me where the AMB is located in LTspice, I can tell you.Hmm now I am a little bit confused! Is the ABV same as ABM or not?
Hehehe okay then, it is the same!If you show me where the AMB is located in LTspice, I can tell you.![]()
I went through it and am pretty sure that I have to just give up! Its just too much for a junior ltspice user like me. Thanks though crutschow.I meant ABM.
So if you have any questions after reading that help file, get back with us.
And what should it output when the 'data voltage' (which I take to mean the Vfsk voltage) is not zero?so that it outputs 2kHz when the data voltage is 0.
If not zero (say 1V) then output =4khzAnd what should it output when the 'data voltage' (which I take to mean the Vfsk voltage) is not zero?
Thanks Bordodynov. Yet, its too difficult for me to relate it to my inquiry.
