Servo input: PWM or analog
Status
Not open for further replies.
lisandro
Joined Jul 26, 2007
5
Hello all,
I am working on a "IR sensor/Schmitt Trigger" which outputs an analog signal to a Servo Motor (HS-322HD), however when plugging the servo to the Schmitt circuit it does not work
The servo seems to be wanting a PWM signal as it is going on and off in an unsteady fashion. Does this servo works with analog, if not, what would be the way to go?
The application: wave the hand at the IR sensor and have the motor turn on (a certain # of degrees) and then off.
Thanks for the help!
Status
