Series transformer at mains input
Lolrapa
Joined Sep 19, 2018
24
Hello, I'm taking apart an old tv and I found some strange transformer at the mains input I dont know what is doing there. This is the circuit
The output goes both to a regular transformer and directly into the main board of the tv.
I think is doing some kind of current comparison? There is no sensing element like a reel switch or a sensing loop.
Do you know whats the name of this configuration so I can do some further research?
Thanks!
LesJones
Joined Jan 8, 2017
4,524
It is a common mode filter which attenuates electrical noise from the switch mode power supply. It helps reduce radiated interference from the mains cable. It also attenuates noise that is on the mains supply when it enters the TV. I would also expect to see a capacitor between the two wires exiting the right hand side of the schematic.
Les.
Papabravo
Joined Feb 24, 2006
22,110
Les.
The TS said "old TV". What makes you think there is an SMPS inside, Les?
MaxHeadRoom
Joined Jul 18, 2013
30,772
Many 'old' TV's used a common mode choke or two on the input, some did not use any transformer or SMPS, just straight into a bridge or rectifier tube, the tube htrs were in series.
There were many variations over the years.
Max.
