Question about switching transformer series/parallel
2155X
Joined Jun 5, 2018
7
I recently just spent quite some money on equipment which I've always wanted: a big 600VA transformer and some extra parts to rectify and use it.
The transformer:
24-0-24V; 2x12.5A.
My idea is to make a power supply in which I can flip a switch so the wiring can change: Series; off; parallel. That way, I could get 48V or 24V with double the current.
I've tried asking around a few friends of mine but no one really knew how to do it. I would appreciate it if you guys would help me out with this as I really don't want to blow up the transformer or the $18 capacitor for it.
Ylli
Joined Nov 13, 2015
1,092
Since the two secondary windings have a fixed connection for the center tap, you can not connect them in parallel. You would need to have two independent 24 volt secondary windings.
Ramussons
Joined May 3, 2013
1,569
Use a Bridge Rectifier. You will have 24 Volt Bi Polar supply; 48 Volts overall.
Such a high capacity transformer is very likely to have 2 independent windings connected together as a centre tap. In which case, you can separate the windings and get what you want to do.
Ramussons
Joined May 3, 2013
1,569
You can use a DualPoleDualThrow to choose between Parallel and Series setup.
If you use a DualPoleTripleThrow, you can have a Open in between.
Just make sure that the contacts are rated to handle the current. Also ensure that, when parallelling,
* the voltages in the 2 windings are exactly the same, else you will have circulating current between the windings
* Polarity of the windings so you dont create a dead short.
