serial half duplex 9600 8n1
BobaMosfet
Joined Jul 1, 2009
2,211
What is this ? and where are the checksums Newby in all this so forgive me
Understand that the characters you're seeing are only representations of the binary data actually being received. If your baud rate is correct. If your baudrate is wrong however, you're just getting representations of junk bits.
JohnInTX
Joined Jun 26, 2012
4,787
It looks like binary to me, too. Note the character representations of some of the control characters. On the bottom line is NUL NUL NUL just before the ASCII 'F'. That is binary data 00h 00h 00h 46h displayed as ASCII characters. The good news is that RealTerm appears to be able to display hex, binary etc so search around for that in the terminal menus.
From the RealTerm description:
Binary display modes -Hex,Int,Float,Signed/Unsigned,
https://sourceforge.net/projects/realterm/
There's likely more than that going on but starting with a hex output would be good.
Good luck and welcome to AAC!
Zener 5v
Joined Nov 19, 2020
6
Zener 5v
Joined Nov 19, 2020
6
11 seems to be master 0E in hex as on screen is address E on the bus 01 is the number of line the devices are connected as there is 3 independent bus lines the hex code is on the screen thanks again
