Sequential Circuit for a Coin Collection Machine
Dewy
Joined Oct 27, 2022
10
A coin collection machine is to be designed to facilitate the collection of old Jamaican coins. The denominations are 5 cent, 10 cent, 20 cents and 25 cents. In the initial phase, the machine is only allowed to accept a total of 30 cents. Once the total is reached the machine displays the total and resets, allowing the user to continue the deposit if they so wish. If the total is not reached, the coins will be refunded. The plan is to use a sequential circuit for this circuitry. As computer science students, you and your team is being asked to design a prototype for this machine.
38,814
Is there a question there?
This is Homework Help not Homework Do, so we will help you with the project, but you need to show us your best effort.
WBahn
Joined Mar 31, 2012
33,193
So, what is supposed to happen if the first coin is 20 cents and the second coin is 25 cents?
What determines that the total has not been reached? What if the person puts in 10 cents, then quickly puts in 10 more cents, then waits several minutes and puts in 10 more cents. Was the total reached or not?
Dewy
Joined Oct 27, 2022
10
The user should be refunded and the machine reset back to 0 as the coin machine should only be able to accept a total of 30 coins
Dewy
Joined Oct 27, 2022
10
Update my lecture changed the project so we are no longer doing this assignment. Question how do delete this post?
Jerry-Hat-Trick
Joined Aug 31, 2022
849
That's a shame, because it's quite a nice problem. Since all coins are a multiple of five maybe a decade counter would count 1 for 5 cents, 2 for 10 cents and so on. Getting to 6 would confirm the correct 30 cent total. Coins down the shute could pass opto interrupters to trigger counts but this is made harder because the larger coins would typically be made to fall away from the shute sooner - mechanically resolved by diverting coins to a parallel shute which incorporates the opto interrupters so the larger coins travel further.
Dewy
Joined Oct 27, 2022
10
Thank you, well now I have a new assignment that I am having issue with.
