separating circuits series/parallel
phantomvs
Joined Jan 19, 2016
39
Ok so here it goes i got this questions that asks me to find the voltage on R4
It tells me :
R1=100 ohms
R2= 1000 ohms
R3=500 ohms
R4= 1000 ohms
R5=500 ohms
So what i did is find the total resistance of R2 &R5 its 333 ohms
then added R1 + R3+R4 , So 100+333+1500 = 1933 ohms
Find the total amps At=0.10 amps
Then did R1 x At = 1.03 volts
and so on but i think i screwed up somewhere ?
33,325
You need to be more methodical in documenting your work. For instance, you say
then added R1 + R3+R4 , So 100+333+1500 ...
R1 = 100 Ω, so that's your first term.
R3 = 500 Ω, which is no where on the right.
R4 = 1000 Ω, which is nowhere on the right.
333 Ω, which is no where on the left.
What your equation tells me that you are doing is
100 Ω + 333 Ω + 1500 Ω = R1 + (R2||R5) + (R3 + R4)
Are R1, (R2||R5), and (R3 + R4) in series? Remember, to be in series, whatever current flows in one MUST flow in each of the others.
phantomvs
Joined Jan 19, 2016
39
Your right, it thought R3 and R4 were in series but its parallel
So R1 is in series with the rest of the resistors.
So if i do 1/Rt= 1/R2 + 1/R5 + 1/R3 + 1/R4 = 166 ohms
Then add in the R1 166 + 100 = 266 ohms
I/R = 0.075 Amps for I-total ?
33,325
But are R2, R3, R4, and R5 all in parallel? Remember, components are in parallel only if the exact same voltage appears across all of them. Is the voltages across each of these four resistors the same?
You are trying to just throw values at regurgitated formulas without taking the time to think whether or not those formulas apply.
Take it step by step. Identify two components that are either in series or in parallel. Then combine just those two components and replace them with their equivalent. Then repeat this process until you get down to just a single equivalent component.
phantomvs
Joined Jan 19, 2016
39
I think thats it , i am not seeing the whole picture.
From what i see, R3 and R4 are in series but parallel to R2 and R5
That would then be in series with R1 ?
Its the R3 and R4 that get me the way they are connected.
33,325
If R3 has some current flowing in it, must that same current also flow through R4? If so, then they are in series. So replace them with a single resistor, perhaps called R34, that is the series equivalent of R3 and R4. Redraw the circuit with that replacement. Then go from there.
hp1729
Joined Nov 23, 2015
2,304
It tells me :
R1=100 ohms
R2= 1000 ohms
R3=500 ohms
R4= 1000 ohms
R5=500 ohms
It might be easier to understand if you redraw the circuit as you go along step by step.
Figure R2 and R5 in parallel then redraw the circuit with R2||R5 as one resistor.
Figure R3 and R5 in series then redraw the circuit with R3+R4 as one resistor.
Then figure these two resistors in parallel.
Then add R1.
phantomvs
Joined Jan 19, 2016
39
So i redrew it and from what i get , doesn't seem to make sense.
I drew R1 as 100 ohms and the put R34 in series with 1500ohms and put R25 in parallel at 333 ohms.
I think i got lost somewhere. Even when i add the R1 with R34.
I will try to post a pic.
phantomvs
Joined Jan 19, 2016
39
this is what i was thinking, sorry for the cheap pic.
But what i did is
R2R5 (333) R34 (1500)
So 333 x1500 / 333+1500 Gives me 272.50 ohms
Then i added in R1 at 100 ohms so 372.50 ohms
At = V/R So 20v / 372.50 = 0.05 Amps Total
Any of this sound right ??
33,325
Again, take it one step at a time.
Draw a circuit in which R3 and R4 have been replaced by their series equivalent. It should look something like this example:
You are trying to do too much at once and it is clear you aren't ready for that yet and that you are making needless mistakes as a result. Don't worry, we were all there at one point and you will quickly move past the need to be so painstakingly careful.
hp1729
Joined Nov 23, 2015
2,304
But what i did is
Sounds good.
33,325
But what i did is
This verbal description doesn't come close to your schematic:
phantomvs
Joined Jan 19, 2016
39
Sorry about that pic, i uploaded wrong one.
I don`t have access to a pic right now, but this is what i did .
So basically i took R3 and R4 and added them together as its a series circuit.
Then created 3 parallel circuits . One under another .
So R2 1000 ohm parallel to R34 1500 Ohms parallel to R5 500 ohms.
Did the parallel formula and came with 277,77 ohms and added 100 ohms of R1.
Found the total amperage I equals 20v / 377.77 equals 0.05 amps
Now i know parallel circuits voltage is the same and series current is the same.
Original question asks for R4 volts , that is where i am stuck.
Unless i screwed up somewhere on simplifing the circuits.
Thanks again for your patience :)
33,325
If you could find the current going through R4, could you figure out the voltage across it?
If so, can you figure out a way to find the current going through R4?
hp1729
Joined Nov 23, 2015
2,304
Finding R4 voltage.
After you find the total resistance of R2, R3, R4 and R5 consider a simple series circuit made of R1 and R2345. Find the voltage across R2345. Then consider the series circuit of R3 and R4 to find the current through R3 and R4, then the voltage across R4.
hp1729
Joined Nov 23, 2015
2,304
This is what i had drew
Super. 20 V did you say? Total resistance divided into voltage gives you current. Current times R2345 ohms gives you voltage across R2345.
R2345 voltage divided by R34 voltage give you R34 current,
R34 current times R4 gives you voltage across R4.
