- Joined Jul 18, 2013
- 30,772
I have one working about 4mm using a ST input to a Picμ.
It might if you use a filter - the white background reflects all colours, if you can figure some way to use blue light - the red pointer will reflect less of it than the white background.Does such sensor can tell the difference between red and white, or the difference of 1 mm height? Can you link me to a good par for this?
Good job! I like it. Can you feed LED by pulse 1...10 kHz voltage and put signal from sensor through capacitor on input of any high gain amplifier?I tried it with very crude setup; blue 5mm LED @ 20 mA, Si detector, 1 mm wide X 7 mm long, white paper, & 1 mm red wire. LED & sensor angled about 30 deg. paper about 1 cm in front. Detected wire moving back & forth. Worked about as well with white wire as it did with white LED. OK with real photo reflective sensor, K but spacing is critical, about 5 mm, & not as sensitive to wire movement.
Using pulses may be necessary so that mains modulation from room lighting can be filtered out.I believe that a modulated LED could be used but from what I saw direct detection with a comparator could work.
Turn ON-OFF incandescent bulb close to test area, then you will see big difference.There were 5 LED lights on in celling when tests were made, no interaction.
Max, I agree with you. QRE1113 contains 48% electro-optical efficiency infrared LED, and phototransistor, spectrally matched with LED. At very short distances illumination intensity from LED much more than any possible intensity from ambient light.I have tried incandescent and florescent right above the QRE1113 with no effect.
