Sending data out of a PC
Bamerni
Joined Jun 26, 2016
53
Hello everyone
I have specific signals in my PC and I want to send them out to a circuit connected myself.
What is the method that I can these signals
Is there a need for a specific hardware to be connected to my PC to do this job or a specific software installed in my PC?
thank you in advance
34,973
Hello everyone
The answer is Yes and Yes.
But you do have to elaborate what you mean by signals.
You can also transmit data by smoke and mirrors, light and sound, radio waves and email. Take your pick.
Bamerni
Joined Jun 26, 2016
53
Ok, thanks to all for their answer
To describe my problem more,
I generate specific signals in Matlab (I can generate them even in Visual Basic or Visual C) and now I want to send these signals out to a card that I build to examine my circuit and to complete my project.
To be more specific, my signals are neural like signals.
now what is your recommendation to me to do, or what to use and how to use any part you advise it to me
ian field
Joined Oct 27, 2012
6,536
You have a choice of RS232, USB and whatever printers used to use.
The printer port is (was) easiest, but I don't think many have them anymore.
Most recent M$ OS's won't allow direct control of ports - there's various patches that can be found online, but beware - "thar be dragons".
panic mode
Joined Oct 10, 2011
5,114
what is your circuit? what is the volume of data you plan on sending?
RS232 is simple but it is not going to cut it for large volume due limited bandwidth and cable length.
Bamerni
Joined Jun 26, 2016
53
Ok, thank you again for your replies
I don't have RS232 port on my computer, also I more prefer USB.
my signals have sampling frequency about 20 kHz and their length don't exceed 10 second
So, if I want to use USB what I hardware part I need and what software I need and what Ian field say [but beware - "thar be dragons"].
34,973
TS said he is generating 20kHz "neural like signals" from Matlab.
Simple enough. Just output the signal using wavplay( ) or sound( ).
Plug into the earphone/headphone or line output jack that there you'll have your signal. No additional hardware required.
shteii01
Joined Feb 19, 2010
4,644
You probably do have RS232. The last few motherboards that I bought did not have RS232 DB9 connector, but the motherboards did have pin outs for it. When I needed DB9 connector for the fax modem, I just bought a bracket with DB9 connector and plugged it into the RS232 pin out on the mobo.
shteii01
Joined Feb 19, 2010
4,644
If you use sound card, a cable like this might be helpful (or not). I got a similar cable from work when they were throwing random stuff away. That is the only reason I learned of its existence. I would have never though of combining 3.5mm audio jack with DB9.
Bamerni
Joined Jun 26, 2016
53
I will try this idea it is look simple
Bamerni
Joined Jun 26, 2016
53
unfortunately, I am using a laptop
