Sending analog data via 433MHz modules
@lpha
Joined Feb 21, 2012
34
Hello
what is the best way to transfert at 433MHz via Aurel Modules three analog inputs 0 to xx mV or 0 to 5V ???
Nobody use a 433MHz transmissions in my location, so i think that I dont need to coding data
Modules are Aurel Tx boost 400mW (AM) and Rx is superheterodyne receiver
bertus
Joined Apr 5, 2008
23,027
From the datasheets I can tell the modules are designed for digital communication.
If you want to transfer the analog signals using these modules, the signals need to be digitized.
@lpha
Joined Feb 21, 2012
34
ok, but the question is how can I digitize the 3 analog inputs ?
how is the best IC to do this, and how can I do to serialise the 3 digital data ?
It will be ok with the DTMF coder/decoder ?
kubeek
Joined Sep 20, 2005
5,796
A microcontroller can do both digitizing and serialising the data, as well as error checking and ensuring the packet was delivered.
rogs
Joined Aug 28, 2009
279
No - the modulation frequency is only 4KHz, so any 'digitized' analogue signal can only have a maximum frequency of 2KHz (Nyquist Theorem max --in practice a bit less!)
As kubeek says, it's best to use a microcontoller to 'digitize' your data, but you need to keep the 'analogue audio' bandwidth below 2KHz....
bertus
Joined Apr 5, 2008
23,027
You can not use the DTMF devices as the signals are still analog.
The modules ONLY accept digital signals.
As for the analog signals:
How fast and how accurate do you want to transmit them.
A higher number of bits used for the digitizing will reduce the speed of transmission.
