Self latching circuit
eetech00
Joined Jun 8, 2013
4,745
I have double checked it and it is wired correctly. Could there be any leakage through PMOS? Since when I put an oscilloscope probe to Enable signal it works as expected. Without it I can not switch PMOS off. I guess the autostart does not work and a device is switched on because of the leakage as well? Any idea, please?
Change Q1 circuit to this:
jan.sedlar
Joined Apr 14, 2021
31
The 1M values are too high.
D2 provides quick discharge.
D1 prevents voltage feeding back into mcu output.
I have changed the circuit but there is the same issue. When I put an oscilloscope probe to enable signal, it works as expected :-(.
BTW do you think I can use LTC2954 in some way?
