seeking for two things- chargers
Status
Not open for further replies.
tcmtech
Joined Nov 4, 2013
2,867
I doubt you will find a single port USB power device that is 5 amp capable simply due to inherent design limitations USB sockets in general.
Even with the high current 3.5 amp capable USB 3.0 ports they are at the upper limit of what can be handled simply due to the inherent USB cable voltage drops that happen unless unrealistically large and less flexible cabling is used.
As for solar chargers to get to 2 amps at 5 volts and be stable in most typical good outdoor lighting situations the panel would have oto be around 2 square feet or larger in size. Indoor even larger.
Mussharraf Hossen Shoikot
Joined Jul 28, 2017
24
i am waiting for the brands and model names. this is a shopping+seeking kind of post.
Papabravo
Joined Feb 24, 2006
22,116
How do you know if such a thing exists, and why do you think we should do your investigation for you? You have access to the internet and I presume you can use google to search for things that meet your requirements. If you had posted the results of your searches and said I'm having trouble finding what I want, then you might find a more sympathetic audience. You're essentially like the guys that ask for people to do their homework for them.
Joined Jul 28, 2017
24
Then you might be waiting for a while. Internet searches are free and something everyone should learn how to become effective at.
give me the data volume, the speed, the physical and psychological abilities to do the searches, surf through the results to sort things and then get them out of the various clickbaits and more and if you cannot, refrain from replying to my posts at all. however, as is the nature of humans as evolutionary psychology shows, the advice would most likely make you more rebellious and try to attack me verbally as physical attacking is unavailable to you people as option, in such a case, only the site admins can give the word on whether you people get to have the word on the rules or i get to. awaiting moderator response.
Papabravo
Joined Feb 24, 2006
22,116
Sir, I am trying to do two things:
  1. Elicit from you the information I might need in order to help you.
  2. Direct you in a productive direction to encourage other people to help you.
You have no cause to take such a tone with me, and I will answer or not answer your questions as the mood moves me. It is a public forum after all, and as much as you might like to dictate the rules -- you cannot.
Status
