Seeking Assistance for 4-Bit Counter Project
weesdf
Joined Oct 12, 2024
6
Hello everyone!
I’m currently working on a 4-bit counter project using a 7493 4-bit Synchronous Counter IC (or 7473/7474 Flip-Flops ICs), and 1 a 555 timer IC to generate a 1 Hz pulse. The project involves utilizing two 1-digit seven-segment displays and requires various digital ICs, resistors, capacitors, and a breadboard with jumper wires.
I’m looking for guidance on the following:
1. Circuit Design: Any tips on designing the circuit layout effectively.
2. Component Selection: Recommendations for specific digital ICs or other components that might work well.
3. Troubleshooting: Advice on common issues that could arise during assembly and testing.
4. Visual Aids: Any resources or examples that include visual aids for circuit design.
If you have experience with similar projects or can provide any insights, I would greatly appreciate your help! Thank you!
DickCappels
Joined Aug 21, 2008
10,661
How many bits do you want out of the counter?
What do you plan to drive those outputs?
What chips do you have available?
It looks like you are comfortable with 7400 TTL parts . Or do you prefer CMOS outputs?
What power supply is available for this project?
What do you think the counter should look like? Let’s see your best attempt so we can help you.
weesdf
Joined Oct 12, 2024
6
Hi! I need to create a 4-bit counter that counts from 0 to 15, using a 555 timer for clock pulses and a 7493 4-bit counter IC to handle the counting. The design should directly drive the two seven-segment displays without using a decoder, relying on a combinational circuit for proper display.
Yes, I'm comfortable using 7400-series and the power supply I'l use is a 5V DC.
weesdf
Joined Oct 12, 2024
6
Welcome to AAC!
That isn't a synchronous counter.
From Texas Instruments:
How do you plan to do this?
I plan to do it using the 7493 IC as the 4-bit counter, which will count from 0 to 15 in binary. To generate the clock signal, I’ll use a 555 timer IC set to output a 1 Hz pulse. The binary outputs from the 7493 will drive two 1-digit seven-segment displays directly.
I’ve gathered the necessary components and will be assembling everything on a breadboard with a 5V DC power supply. However, I need help with the proper wiring and setup, especially with connecting the seven-segment displays and ensuring the clock and counter function smoothly. Your expertise and guidance would be greatly appreciated!
WBahn
Joined Mar 31, 2012
33,222
Since this is homework, you need to present your best effort to get as far as you can and then describe what problem you are running into. We won't tell you how to do it, we will help you get over specific stumbling blocks that you encounter so that you can learn and move forward.
dl324
Joined Mar 30, 2015
18,473
This isn't as easy as you appear to think.
Since this is homework, you need to do most of the work.
weesdf
Joined Oct 12, 2024
6
Yes, I know and understand. And I'm still on the planning stage.
Do you think it would be better to use the 7473/7474 Flip-Flops ICs instead of relying solely on the 7493? I’m open to suggestions.
weesdf
Joined Oct 12, 2024
6
Hello, I understand! I’m currently still in the planning stage and am committed to getting as far as I can with the project. Any suggestions or advice you have would be.
And I want to ask if do you think it would be better to use the 7473/7474 Flip-Flops ICs instead of relying solely on the 7493?
