Screw size for slide switches.
bertus
Joined Apr 5, 2008
22,930
Sergio34
Joined Nov 10, 2018
52
The size of the screws should be given in the datasheet of the switches.
It could me M2 or M3, depending on the overall size of the switch.
Keep in mind that some will be threaded and some not.
I have attached some datasheets to show.
The datasheets are downloaded from this page:
https://cpc.farnell.com/c/electroni...itches?searchref=searchlookahead&pageSize=100
Thanks a lot, I had read datasheets but most of them show dimensions, and I was not sure that 2mm hole means definitely M2 screw for example. I don't know about screws and you happen to know.
Sergio34
Joined Nov 10, 2018
52
They aren't necessarily M anything. They may be UNC, UNF, etc.
Actually this is why I asked, as more datasheets mention diameter only, I was not sure that 2mm corresponds to M2 screw necessarily although it is the logic thought. I will get some M2, M2.5, M3 with nuts and washers and will take it from there.
34,832
What does the spec sheet say?
I took some random slide switch that looks like yours and I believe the thread size is M3 x 0.6.
