Scrapped SATA hard drive and would like to use it in older computer
ebp
Joined Feb 8, 2018
2,332
In disk management there should be two sub-windows.
The upper is a list with several columns and the lower has a box for each physical drive.
Go to the lower and scroll to find the disk you want.
Right click on each of the partitions (click on the colored bar at the top) and select Properties. This will bring up another window. Under the General tab it will tell you what the Type and File system are. Presumably you want NTFS as your file system. If it already is NTFS you could could assign drive letters and carry on, but it you want the drive as one partition you'll need to delete the existing partitions.
Right click again and look for Delete Partition.
Tonyr1084
Joined Sep 24, 2015
9,744
The drive is not listed as NTFS.
When I open properties it doesn't give me any option to label the drive. Just tells me it's active.
I've already deleted two of the three partitions. Are you suggesting I delete the last partition? How is that going to help? If the drive is deleted then I can't access it. Shouldn't I keep one of the partitions just to get the thing up and recognized? Once recognized I can reformat it. That I know how to handle myself. But pointers are always welcome.
And thanks so far for everyone's input(s).
ebp
Joined Feb 8, 2018
2,332
Have you tried assigning a letter to the remaining partition?
I thought there was a way to format a whole drive without doing that, but it has been so long since I've done such a thing I can't remember.
Tonyr1084
Joined Sep 24, 2015
9,744
I looked but there's nowhere to label the drive or to assign it a drive designation.
I gotta go through my wife's library and see if I can find the XP Professional and reload it using just the one drive. Since the other drives are recognized I can plug them back in later. That way I don't lose my files.
ebp
Joined Feb 8, 2018
2,332
A "rescue" disk (floppy, CD, DVD, USB drive, depending on what you have and what the bios supports - which may not include USB drives) that boots to DOS could be used to format the disk without Windows getting in the way. Disconnect your other hard drive(s) first so there is no risk of mangling one of them.
You can find rescue disks on the web. I haven't look for some time, but I recall both floppy versions and ISO images that can be burned to CD, provided you have tools for doing that.
Tonyr1084
Joined Sep 24, 2015
9,744
Well, I can burn a CD on this computer (iMac). The computer (windows operating system) is not connected to the internet and it's a rather older unit. On the order of 16 years. But I really need to go up stairs to the wife's office and go through her library. I have grown more sure that I can find the disk I need without having to load something from the internet. Hopefully the disk can give the drive a designation and format it as NTFS.
Tonyr1084
Joined Sep 24, 2015
9,744
Didn't find my copy of windows XP Pro but I DID find my wife's copy. My copy has the last authorization code. Hers wasn't recorded.
Anyway, I've attempted to upload XP to the SATA drive but MS said there's no detected drive. I've disconnected the other drives but have the SATA connected and powered. So I don't know what to do next. The SATA drive is just not being recognized. Is this a case where I go into the BIOS? Really needing some help here.
ebp
Joined Feb 8, 2018
2,332
Do you have a floppy drive on the machine? The XP distribution has provision to make a rescue floppy. I don't recall if there is provision to make a rescue CD. I'm fairly certain you can boot from Windows dist disk and then just make the rescue floppy.
ebp
Joined Feb 8, 2018
2,332
If you have a sloppy disk drive
from Windows XP Annoyances for Geeks, 2nd ed
  1. insert floppy
  2. in Windows Explorer, right click the floppy drive icon and select format
  3. tun on the Create and MS-DOS startup disk option and then click start
  4. wait
This makes a bootable MS-DOS disk. It should contain format, but maybe not NTFS. You may have to go back to Windows for NTFS formatting. Other rescue disks I've seen do offer NTFS formatting.
Tonyr1084
Joined Sep 24, 2015
9,744
I think I've solved the formatting problem. What I did was to delete the final partition. The drive completely disappeared. Now, here's the totally useless part of my post - I don't know what I did to rediscover the disk, but it asked if I wanted to partition it. So I said yes. It partitioned and recognized the drive. I had to format it and did so at whatever it was set to, turned out to be 17.76 gig. OK, no big deal I still had a lot of hard drive left that was "Unallocated". So I partitioned that drive and named it drive H. The 17.76 gig is drive G and the 448 gig is H. Maybe I can delete the 17.76 gig partition.
Anyway, when the time comes I'll upload my wife's copy of XP and try and contact MS Windows and get an activation code. I have the key code so there should be no problem. Just going to need the activation code and I should be good to go. Hopefully. { fingers crossed }
ebp
Joined Feb 8, 2018
2,332
You probably didn't do anything. Windows will discover disks after a short time if nothing prevents it.
If you want it to be all one partition you can do it with 3rd part tools. If you want Windows to do it at this point it is simplest to start over with both existing partitions deleted and just say no next time it asks if you want partitions.
A USB dock or adapter can be useful for messing with disks since you don't have to shut down and reboot all the time.
DbLoud120
Joined May 26, 2014
101
Just go on-line and re-register. As long as your copy is legal, you shouldn't have any issues reactivating.
I re-installed XP last month on an old laptop. When I attempted to activate windows, I received a message that the server was not available.
I tried for a couple weeks before I gave up and installedLinux.
atferrari
Joined Jan 6, 2004
5,032
Last time I had to "reinstall" my WinXP, because the original motherboard failed, I used the now "non legal" copy and foun the whole SP3, not reccomended for common users but to OEM (or something like that). Installed with no difficulties it worked OK.
dl324
Joined Mar 30, 2015
18,524
The activation procedure should have given you several choices. Did you try the option to call Microsoft?
Tonyr1084
Joined Sep 24, 2015
9,744
I tried for a couple weeks before I gave up and installed Linux.
What is Linux?
I have two legal copies. I can't find MY copy and my wife is no longer using XP so I'm trying to load her copy. If I could find my copy I believe I still have the authorization code written on the packaging.
Will let you all know how it goes.
joeyd999
Joined Jun 6, 2011
6,559
What is Linux?
I have a legal copy of Linux.
Tonyr1084
Joined Sep 24, 2015
9,744
For those interested, I went ahead and clicked the "Activate" button and it took me to a screen where a couple phone numbers appeared. One was an 800 number, so I dialed it. Got an automated system that sent me a text to my smart phone. There I clicked a button that took me to a screen where I entered the information regarding my CD Key code and it sent me an activation code. At first the code didn't work. I triple checked the numbers and had everything right. So I replied to the question "Did you get an error message? Click YES or NO." I clicked yes and they sent me a new set of numbers; and they worked.
I found another SATA Hard Drive, an 80 Gig and have thrown that into the computer as well. I now have three hard drives, one is a 60 Gig regular hard drive, the one XP is running from and two SATA drives, one is the 80 and the other is a 500 Gig. WOW FOR ME! Now, what am I going to do with all that drive space? I can't get the computer to run solely on just one of the SATA drives (don't know why not). But for now I'm past the crisis of having to "Activate" my XP.
Thanks all for the help.
I still wanna know what Linux is. Is it prone to virus? Does it need an anti-virus? At most I see on the web that it may be an android OS of some sort. Does it come in PC form? How popular is it? How powerful is it?
P General Electronics Chat 2
