In disk management there should be two sub-windows.
The upper is a list with several columns and the lower has a box for each physical drive.
Go to the lower and scroll to find the disk you want.
Right click on each of the partitions (click on the colored bar at the top) and select Properties. This will bring up another window. Under the General tab it will tell you what the Type and File system are. Presumably you want NTFS as your file system. If it already is NTFS you could could assign drive letters and carry on, but it you want the drive as one partition you'll need to delete the existing partitions.
Right click again and look for Delete Partition.
