Scr - Two Tramsistor Circuits
Gabriel Pianez
Joined Oct 2, 2016
10
Hello, if i consider my two transistor operating in saturation mode, how can i analisys the voltage in some points ?
  • VB2=VC1?
  • are they in saturation mode ?
  • VC1 = VE1-0.2?
  • VGG=VC1=VB2?
Thanks!!
#12
Looks about right. Q2 might not become 0.2 volts, collector to emitter. It depends on the quality of the transistor. Some only go to 0.3V or 0.4 V.
Gabriel Pianez
Joined Oct 2, 2016
10
Yeah, i know, i use this value only for a reference, but if VCC = 10V, VC1 would have 9.8 ( for example), but VB2 cannot assume this value, because Q2 is an emitter common circuit.
#12
The thing throwing a wrench in the works is that Rl will use up nearly all the 10 volts when the triac comes on.
Emitter Q1 will reduce to about 0.4V (according to your beliefs about saturation voltage) and collector Q1 will be reduced to the Vbe of Q2.
#12
In the real world, Vbe Q2 will be about 0.6V and Vce Q2 will be about 0.5 volts.
That Vce Q2 will add to the Vbe Q1 which is another 0.6V.
Datasheets about SCRs usually show 1.2 to 1.4 volts MT1 to MT2 under maximum load current.
hp1729
Joined Nov 23, 2015
2,304
  • VB2=VC1?
  • VC1 = VE1-0.2?
  • VGG=VC1=VB2?
Thanks!!
It looks like the Base-Emitter junction of the PNP is going to be overwhelmed. Are SCRs built to different standards than discrete transistors in this area?
dl324
Joined Mar 30, 2015
18,476
Not much to analyze. If VGG is high enough to start turning on Q2 (and not high enough to destroy the transistor), IC2 will increase. That will increase base IB1 which will increase IB2. Regenerative feedback will cause both transistors to saturate.
The voltage at Q1E will be VCE(sat)Q1 + VBE Q2. The saturation voltage of Q1 depends on the value of RL.
Obviously.
Insufficient information. What is VGG?
VC1 = VE1-0.2?
Assuming Q1 is saturated and VCE(sat) is 0.2V.
VGG=VC1=VB2?
Obviously.
38,855
Yes.
Remember the two transistor circuit is just a model. The physical construction is much different (the SCR consists of four alternating P and N doped silicon layers as shown in your diagram).
Thus the equivalent base-emitter junction of the PNP in an SCR is as large as the other junctions and will handle the full SCR ON current.
hp1729
Joined Nov 23, 2015
2,304
Yes.
So we really can't make an SCR out of transistors?
Other transistor SCR-like devices.
How about an SCR that is activated by a ground in?
A 3 transistor design that doesn't have the base current problem?
A MOSFET input SCR?
Or maybe an all MOSFET SCR? Could we swap N-MOSFETs and P-MOSFETs to get a ground input triggered SCR?
(edited to add ...)
Do I need to add some resistor to ensure off stays off until triggered?
hp1729
Joined Nov 23, 2015
2,304
View attachment 113014 View attachment 113013
A MOSFET input SCR?
(edited to add ...)
Modified drawings attached.
And of course we could build Triacs with each of these ideas.
