Hi there!
I used my multimeter to measure pins of a newly-bought SCR named S4006L. When I used the diode-checking mode, I hooked my probes across the cathode and the gate pin. Whether I swapped the probes, I always got 0.2V. Also, the resistance between those two pins is around 150 Ohms, even if I swapped the probes. Measuring the the capacitance between the anode and the cathode, I got a reading of 8pF.
Here are my questions:
1. When I hooked my positive probe at the cathode and the negative probe at the gate, why I got such a reading? If you see the equivalent circuit of an SCR, the cathode is an N-substance while the gate is a P-substance. This is obviously reverse biasing. Should it show high resistance instead?
2. I would like to know more about the capacitance. If you have any good resources, may I see that too?
Sincerely,
BlackMelon
Sincerely,
BlackMelon
