SCR commutation
Ramussons
Joined May 3, 2013
1,572
Hello all,
I have on my hands, a beard trimmer with partially dead electronics. It has a NiMh 3.7 volts cell and the charging circuit works ok.
The other part which has failed has electronics with ON/OFF and Speed Control.
I intend to wire up some basic electronics with Tactile Switches for ON and OFF and no speed control.
What I am wanting to know is whether the SCR can be Commutated by a MoSFeT as shown.
Your suggestions are welcome.
The Push Button on the Left is ON which triggers the SCR to conduction.
The Right is OFF which is to switch on the MoSFeT to full conduction and Commutate the SCR.
Ramussons
Joined May 3, 2013
1,572
If you use a push OFF switch in series with SCR, maybe it will be easier and no MOSFET needed.
This was my first choice. But tactile switches "Push to Break" is not easy to come by ( here), and the permissible current is only about 30 mA. I need to handle about 250 mA.
Ramussons
Joined May 3, 2013
1,572
This circuit from EEVblog will do the job without the 1volt or so loss over the SCR.
Another choice, Thanks.
Won't the 2N3904 on the Gate of the MoSFeT need a Pull Down resistor on its Base? To avoid any Collector leakage?
And how does the MoSFeT shut Off?
38,848
Below is the LTspice sim of an alternate action switch using one P-MOSFET and one BJT:
It draws only a small leakage current from the battery when OFF.
Ramussons
Joined May 3, 2013
1,572
Thanks to you all. I came across another soft switch using a pair of MoSFeTs from Stack Exchange.
I have slightly modified it. Guess this should work. Comments please.
