This relay is a T73S5D24-12B.
Even though it says "Potter& Bloomfield" on it, doing a search of the number the PDF comes up as "Tyco".
I figure they're the same............
The "Must Operate Voltage" rating for 12V is 7.8 volts, so, I figure that'll be OK (having already incorporated the pin #3 diode in the PCB layout.
Can you concure ?
The only time the relays will be on will be when the clock is at "0000" or the preset value.
I don't think they'll be hurt by being on the small amout of time the clock will be at 0000, etc.
I have one on my mailbox circuit that's lasted for years, staying energized, only to de-energize when the mailbox door is opened (breaking the circuit).
OK, Sarge, I appreciate your assistance...........
Oxbo
Can you concure ?
Oxbo
