Scope Telequipment D61A;horizontal position fault
Hey @patpin! --- Nice to see you back!:) You were one of the first poster's I 'met' following registration with ACC!:D
Another thought -- I've known a 'loose' deflection plate produce symptoms similar to those described -- are you able to illuminate any part of the far right portion of the screen via adjustment of the 'x-position' control?
Best regards
HP
patpin
Joined Sep 15, 2012
405
Hallo, nice to "see" U again. I recovered but the scope didnt...
On EXT X mode (pulling knob at center of time/div) the signal occupies up to 4/5ths of the display. Without EXT X it is only 1/3th; the same for CHAN 2;
patpin
Joined Sep 15, 2012
405
R66 and a few others etc aremarked with an asterix on the diagram which means they are not present on the PCB....!? I dont get that
That usually means said components are located 'off board' (e.g. panel/chasis mounted controls and components mounted to same, etc...)
Best regards
HP
While that probably 'exonerates' the tube (i.e. rules out loose electrodes) it, nonetheless, should be possible to illuminate the extreme right side given sufficient x-axis input amplitude...
Assuming the tube is ok and in light of the (proper) linear operation of the horizontal (i.e. x-axis) amplifier there are only two possibilities:
1) Static (i.e. 'DC') 'imbalance' Re: horizontal deflection...
2) Magnetic interference (by inadvertently magnetized chassis, case, etc...) --- Very unlikely but not unheard of...
By way of 'stamping out assumption' Please try the following:
1) Set the instrument for External X-Axis input:
2) Set the gain of the channel processing the X-Axis input signal to maximum
3) Apply a Ca. 10v PP sine wave to the channel described in step 2 (above) --- Note: Please see postscript...
Rationale:
--Application of 10V PP to make certain the trace will more than reach the 'sides' at Max gain
--Use of a sinusoidal (as opposed to rectangular) waveform to produce a 'continuous' trace
Please advise us of your results:)
Best regards
HP
PS: For the sine wave 'generator' you may use any (line isolating) PS transformer featuring a low EMF output -- the output EMF is not critical...
ian field
Joined Oct 27, 2012
6,536
@ian field: Can you explain "shift control" ?
I'm not sure how it works on a scope, but basically it imposes a small bias on one deflection plate and subtracts the same amount from the other plate.
The vertical plates are probably driven by a long tailed pair, so the shift control is probably as simple as an offset pot where the emitters meet the tail. The horizontal drive is a sawtooth, so the drive circuit is most likely different.
patpin
Joined Sep 15, 2012
405
Hello thanks fr yr answ. What do you mean by max gain: I have from 5V/ div to 10mV/div; do you mean in this case 10mV/div; I only have a trafo generating 25V at hand (measured with voltmeter). I have tried with 25V AC and 10mV/div; horizontally nothing changes;
I also tried to augment the 'trace length' with another potmeter (R77)(on sweep generator). It helped a bit (20%) but not more at the end of the potmeter turns. In the last case the display is used for 50%. (not EXTENDED X)
To clarify: In general, when such an instrument is set for 'External X-axis input' (AKA "X-Y" or "X,Y" mode) one channel will process the vertical (Y-axis) input signal whereas the other will process the Horizontal (X-axis) input signal...
Correct -- Max gain=most sensitive range...
At a setting of 10mV Per division, 25V RMS (i.e. > 70v P-P) should produce more than 700 times the deflection required to 'reach' both 'sides'...
OK... This is going to sound a bit 'goofy' -- But I hope you'll give it a try all the same:)
1) Set the scope for display of the calibrate signal in such manner that it would, were the instrument properly functioning, give a full-width display...
2) Carefully - Physically invert the instrument while gently shaking same -- note any changes in the display...
Rationale: Inasmuch as we have investigated the 'usual electrical suspects' I am attempting to eliminate loose or 'open' electrodes (Spec. deflection plates and connections thereto) as possible 'culprits'...
Note -- There remains much more to be investigated on the electrical/electronics 'front'! -- I am merely attempting to 'rule out' "800 lbs gorillas" - as it were!;)
Best regards
HP
ian field
Joined Oct 27, 2012
6,536
Best regards
HP
The gorilla is a bit excessive - an angle grinder maybe?
That's what I get for mixing metaphors;) -- 'elephants in the room' might have been more apropos even if less 'dramatic'/'comic':cool:
PS - angle grinder isn't parallel:confused: -- Did you, perchance, mean a organ grinder's monkey;):D
Lousy auto-spellers!:rolleyes:
No change on shaking gently. I can also turn the tube on its long axis. No deformation of the signal either.
Ok -- based upon that and other observations I feel we may safely assume the tube is in good condition:)
So.. Please allow me a little time (a day or so) to get caught up on 'life' -- then I'll carefully study the schematic with the aim of providing you with an 'interactive trouble shooting guide' (i.e. a list of measurements to make, components to check, etc...) --- In the meantime please watch the thread as further assistance may be forthcoming from others!:):):)
Very best regards
HP
