Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
Good! -- But is the soldering iron grounded? -- If not, it is advisable to first determine the magnitude of the maximum leakage current - then, if said current is small, ground the external metal surfaces of the soldering iron... Otherwise you will very likely damage components should you use the iron on equipment while it (the equipment) is connected to the mains...Mains ground is connected to frame at scope interior.
If, on the other hand, the iron is grounded -- then either its ground or the scope's ground is faulty...
Best regards
HP
