Schematics for a horizon ct81 control board
agepag
Joined May 16, 2019
So my treadmill will not run, everything else works, so I think it is the control board. Does anyone's have access to the board schematics?
Thank you
Adrian
padard
Joined Dec 10, 2019
5
hi ,
i need schematics too. i have same problem and replace all caps, mosfet, kikback diode, zener diode,.
thank you have a nice day!
pat
padard
Joined Dec 10, 2019
5
Don't recognize that one.
Have you tested the motor?
Max.
yes motor spin with my battery pack from 12 v cordless drill, replace mosfet irpf260n, kikback diode, all caps, u4 (un136 chip) u5 (tlp521 chip) u3 ( uc3842 chip) big relay , and 2 zener diode. and still have same trouble. treadmill work for up down, display work. i check speed sensor and belt sensor and test ok.
this reason need schematics
padard
Joined Dec 10, 2019
5
i,
i have treadmill with control board problem on horizon fitness ct 81 board is JDYF02L. replace all capacitors, zener diode. u3 (uc3842b) u4 (6n136) u5 ) (tlp521) q4 ( irfp260n mosfet) ) d4 ( 30ua60 kickback diode)
i have same problem speed motor not work but display and up and down motor work, no error message.
i need schematics or infos for troubleshoot this board
thanks you have a nice day !!
Hi, were you gents able to diagnose and repair your MCB's? I have a CT7.1 with a similar issue. Belt started stopping intermittently while running, I would cycle the power and unit would start normally...now top unit asks for speed but MCB will not output to motor. Any help would be appreciated...especially in this Covid isolation... :p
20190615_103157.jpges el esquema de arnés para placas de 8 hilos de Jhonson fitness espero te sirva
Translate to English Text.
DickCappels
Joined Aug 21, 2008
10,661
Este es un foro solo en inglés. No se permiten otros idiomas.
English version:
This is an English Language only forum. Other languages are not permitted.
