scart connectors mystery
aag
Joined Aug 11, 2018
18
I need to attach 21 little cables to these connectors. Soldering does not work; the surface repels the solder. I suspect that some crimpable pins are needed. But which ones? There are a million different pins one can buy... Can somebody advise me?
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
How much soldering experience do you have? Soldering works for me. If you're having problems, try leaded solder and tin the contacts before trying to attach wires.
aag
Joined Aug 11, 2018
18
I am terrible at soldering! I managed to make one such connector by soldering, but it was a major pain. I am wondering whether pins and crimps may be the more appropriate way.
aag
Joined Aug 11, 2018
18
Thanks Hymie. That's a very clever suggestion indeed! However, I intend to use some of the wires for powering LED strips, and the current will be substantial. I therefore need at least 0.5 mm2 wires. I would be wary of thin AV cables for that purpose.
ericgibbs
Joined Jan 29, 2010
21,567
hi aag.
Buy some solder flux paste, apply a little paste to the pins, then solder tin the pins using a 60Watt soldering iron.
Thoroughly clean off any residual flux from the pins, then solder on the wires.
E
