same duty cycle with NE555 with single potentiometer
AnalogKid
Joined Aug 1, 2013
12,217
The circuit in #20 will not work and the chip will fail. The chip would fail because DIS and OUT are complimentary outputs. When ever OUT is high, DIS is low, trying to short OUT to ground. Not good. For the hysteretic oscillator, the discharge pin is not used. OUT goes through the pot to THRS and TRIG. DIS is left floating.
As for the duty cycle, it is very difficult to say. The LMC555 datasheet (2002) does not have plots of output voltage vs current. Also, the values in the tables are for two very different output currents. Reading between the lines, my guess is that the two output transistors are well matched at currents below 1 mA, so the symmetry will be within 2%, and probably within 1%. Maybe one of our local 555 fans has run their own tests ... ?
ak
eetech00
Joined Jun 8, 2013
4,716
I tried this circuit on the bench and it produced exactly 50% duty cycle independent of frequency.
The sim shows 14vdc supply but I actually used 12vdc supply on the bench. But it does add a transistor to the mix.
eetech00
Joined Jun 8, 2013
4,716
Does the pot have all 3 terminals attached to the circuit? It looks like you dont have a valid pot symbol and its just being used as a resistor with 2 terminals attached. Have you tried the circuit down to 5v?
Hi
Yes...the pot is wired as a variable resistor (all three terminals used) and the symbol is valid for a variable resistor configuration. The circuit works at 5 volts and the test circuit is running at 22 Hz with parts I had in my junk box.
eT
